Rear ends
Old May 24, 2013 | 09:17 PM
OEMJ's Avatar
Default Rear ends
I have 1995 Chevy C3500 "6.5" 5 speed manual with dual "wheels." Can anyone tell what other rear ends will bolt into this? I have "4.11"and want around "3.08." I won't be hauling anything heavy, I bought this because there are only 37,000 miles on the truck, a one owner, documented. Drove it home, a little over 400 miles, no problems, but need better fuel mileage.
I'd like to just bolt one in from a 2500, but don't know what all will fit. Thanks
Old May 29, 2013 | 02:21 PM
racer55's Avatar
Be tough to find gears that low from a 2500,maybe a suburban but even then 3.42 might be the best you can find?
As for spring perches,88-2000 should all be the same however you will then have missmatched track widths between frt and back if you want to keep single wheels because of the dual wheel offset up frt..
Old May 29, 2013 | 06:52 PM
OEMJ's Avatar
Thanks, I'm not to concerned about the tracking fr. to back. If I get one from a 2500, will i need to carry 2 spares or will the bolt pattern be the same, do you know?
Old May 29, 2013 | 09:33 PM
racer55's Avatar
Depends if you get a 6 or 8 bolt axle?
8 bolt should be the same,so I guess you would want to carry the original dually spare to fit all 4 corners even if the offset is different on the back.
Also if you do end up using the large offset wheels install the backs wide-not narrow.
Old May 30, 2013 | 09:52 PM
SRR's Avatar
SRR
Going to a taller tire will lower rpms also.
Old Jun 14, 2013 | 04:39 PM
jonesjj35's Avatar
Has anyone upgraded thier rear end to a locker?
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
dougcarlo
Oct 18, 2014 03:15 AM
