Cummins four codes? Help!
Old May 19, 2013 | 07:02 PM
commonrailman's Avatar
Default Cummins four codes? Help!
My 01 sport 6 Spd has a slight miss every now and again. Threw ECM code p1693 ecu p0252 p0253 p0254. What's causing this? Only happens about once every trip. Thanks. Ha a quadrille adrenaline with v2 monitor by has bn unhooked around 2 wks now so it's not the chip. Thanks for all help
Old May 19, 2013 | 08:17 PM
stodg73's Avatar
P1693 - Code cleared in JTEC module
P0252 - Injection Pump Fuel Valve Stuck
P0253 - Fuel Injection Pump Fuel Valve Stuck
P0254 - Fuel Injection Pump Fuel Valve Current Too High
You might try and clear the codes and see if they come back. However, The 0252 is generally a code for a bad VP44.
Old May 19, 2013 | 09:06 PM
Alright, Im going to reset them hopefully tomorow. I did some investigatin and goin three wires on the vp crimpe pretty badly. And one was tapped with a small piece of wire showing I assume where the chip was in before I bought it. Is there any chance the wires could cause this?
Old May 19, 2013 | 09:33 PM
stodg73's Avatar
Possibly. You might solder them and try clearing the codes.
Old May 21, 2013 | 10:58 AM
Alright, the engine light shut itself off, truck is running like a champ again, but the codes are still showing up. I'm starting to think the wires had a role in this?
Last edited by commonrailman; May 21, 2013 at 10:58 AM. Reason: Automerged Doublepost
Old May 21, 2013 | 11:41 AM
stodg73's Avatar
The CEL will shut off and clear the codes itself after 40 cold to hot cycles.
Old May 21, 2013 | 04:44 PM
Alright, thanks for all the info guys! The help is much appreciated, I'm gonna keep an eye in it and hope thing clear up! Thanks guys!
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
JoeyMiR
9
Feb 3, 2018 10:05 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
