EDGE COMP HELP
Old May 16, 2013 | 09:07 PM
Bruce24Valver's Avatar
Default EDGE COMP HELP
I recently picked up an edge comp box from a friend, now when i hooked the box up i can only get level 4x4 to light up and when i tapped the pump there was no noticeable gains. Is there a difference between the 30300 and 30301. Thanks for any help fellas!
Does anyone know the difference between the 30300 and 30301!?
Last edited by Bruce24Valver; May 16, 2013 at 09:07 PM. Reason: Automerged Doublepost
Old May 16, 2013 | 09:30 PM
BarryB's Avatar
30300 is for 98.5 -00 the 30301 is for the 01 02 but you need the adapter for an 02.
Old May 16, 2013 | 09:50 PM
Well i picked up a 30300, and mines an 01 but everything connected properly. It would only go to level 4x4 on the lights. As soon as i tapped my pump my vp sh*t the bed!? I just replaced my vp, thinking of selling the comp and getting a smarty with 100 horse injectors. Any thought would help out!!
Old May 22, 2013 | 11:59 AM
Al31031's Avatar
what you should do is get the smarty it has the best down low power for sure do doubt. Then you stack it with a tst powermax 3. This is the setup i run and let me tell you it woke my truck right up all the low end from the smarty and tons of top end from the tst pulls hard.
Old May 26, 2013 | 01:47 AM
I am trying to get rid of the edge box as we speak. I like the idea of the smarty, because its doesnt involve tapping my pump.. which i just put in last week, and if i tap the pump or use a stealth plate they will void my warranty! I appreciate the advice, seems like you are running a set up that i am strongly considering!! Only thing holding me back is my stock 47re.
Old May 26, 2013 | 05:13 PM
Al31031's Avatar
Oooooowwww yeah hmmmmm well my advice would be, do the stack with smaller injectors run the stack settings in the basement so you don't fry that tranny and when the time comes for a tranny sell those smaller injectors and put in some bigger sticks and crank the stack
Old May 26, 2013 | 07:45 PM
I like the way you think, thats what i was thinking, maybe a set of 75s and a smarty, when the trannies done (atleast a tc and vb), dump the 75s and get some 125s and the tst. The nice thing is i am running a deep cooling pan and temp sensor. Thanks for all your help!
Old May 27, 2013 | 07:16 AM
BBD Tech Support's Avatar
Likes the smarty over the edge when it comes to the Dodges
Old May 27, 2013 | 07:27 AM
mysterync's Avatar
Do you recommend 70rwhp as opposed to 120+rwhp
Old May 28, 2013 | 10:41 PM
Agreed.
