burping coolant out the degas tank
Old May 15, 2013 | 06:58 PM
bite this's Avatar
Default burping coolant out the degas tank
I got a 2006 king ranch, it's burping coolant and I can smell coolant after long drives. I did a coolant flush a few months ago, changed the degas cap, and cleaned the EGR valve. The truck runs great, no over heating, smoking, or signs of coolant in engine oil. I'm sure the truck has some kind of tuner because it gets awesome fuel mileage. I'm praying it's nothing serious. Any suggestions?
Old May 16, 2013 | 12:01 PM
MillerBoyzDiesel's Avatar
Sounds like you need new head gaskets.
Old May 16, 2013 | 05:10 PM
bobfbigman's Avatar
pull the egr valve and see if it is wet with coolant or if there is a puddle of coolant in the intake,if so the it is a ruptured egr cooler but you will normally get steam out the exhaust when this happens,,,,,,head gaskets are a strong possability
Old May 19, 2013 | 04:22 PM
Bullhauler93's Avatar
Mine was puking coolant when my oil cooler started to clog up. Hard accelerations or high temps for other reasons cause high pressures in the system and cause it to puke coolant too.
Old May 21, 2013 | 06:28 PM
bite this's Avatar
I just serviced the truck, I bought the a new degas cap from the dealer and its alot better. I dont smell coolant or see it dripping like I use to. There is a small amount around the cap after long drives up hill or towing.
Old May 21, 2013 | 06:55 PM
cummin_un_glued's Avatar
FormerVendor
99% chance your gaskets are blown. do a coolant pressure test on it and see what you get
Old May 21, 2013 | 11:42 PM
bite this's Avatar
I am going to try that next. I hope and pray its not the Head Gaskets! Best case scenario the pressure is good, whats next? Oh and btw my check engine light came on and the #2 glow plug is out, got a new plug but whats the best way to remove the plug?
Old May 22, 2013 | 11:46 AM
I doubt the pressure will be good if youre still getting coolant pushed out under load. You can go through the inner fender to replace the glow plugs. The harnesses can be a pain, usually I do the entire bank and have a new harness on standby.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
RatsMC
May 4, 2015 05:25 PM
egghead
Feb 6, 2015 08:03 AM
