Steering loose
Old May 14, 2013 | 05:44 PM
93 12valve's Avatar
Question Steering loose
I can't figure this out my 93 12valve it's steering is really loose, when I turn left all the way I can just let go of the wheel and it will just go in circles until I bring it back, its does the same thing going right but itll bring its self back somewhat,if anybody has any suggestions on what I should do I would greatly appreciate thanks
Old May 19, 2013 | 08:13 AM
montepig72's Avatar
Have you done anything to affect the toe-in? That's what helps the wheels align on their own. An 1/8th" of toe-in will suffice. Other than that you may want to check your tie rod ends for excessive play.
Old May 19, 2013 | 09:39 AM
olsmokey's Avatar
The steering shafts in those truck often cause loose steering also. Check for excessive play in the rag joint and at the pop joint were the shaft meets the steeringbox
Old May 20, 2013 | 09:07 AM
geddy's uncle's Avatar
First, your philosophy is wrong. The first-gen cummins-powered Dodge isn't steered. It's herded ........ Now that I've made the smartassed context-adjusting statement, ditto what was said above. The OEM steering shaft is very, very under-engineered. I've got a Borgeson in my 2nd-Gen and my son's got the other model of Borgeson in his RamCharger. That made a noticeable difference on both trucks. I've seen posts by guys who built their own for, like $35, by looking at a Borgeson or a Flaming River unit, and then buying 2 small U-joints, and a nice piece of slipshaft (that's all a Borgeson is, really) and doing their own cutting and welding. In addition to the tie-rod advice and the toe-out advice, the 1st-gens also have a reputation for frame cracks right near the steering box. There's a lot of places in the steering where ChryCo jacked the job. Fortunately, they did so with really simple, unsophisticated parts.
Old May 20, 2013 | 10:07 AM
Screamin' Metal's Avatar
What He Said!
These things roll around like water buffalo if the aren't taken care of. Tie-Rod ends, Steering shafts, and your gearbox should all be checked. Sounds like it might be time for a complete front end redo!
Old May 20, 2013 | 08:15 PM
93 12valve's Avatar
Sweet thanks really apperciate it guys, ill check that out tomorrow
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
