94 7.3 TURBO DIESEL AUTOMATIC
Old May 13, 2013 | 02:31 PM
ALWAYSREADYROB's Avatar
Default 94 7.3 TURBO DIESEL AUTOMATIC
my 94 ford starts up ok and after it runs a while and warms up it begins to stall and wont start, I pump the pedal and no smoke even comes out of the exhaust pipe....could it be the fuel shut of switch or the Throttle Position Sensor ?
I dont see how it could be the pump because it is less than one year old. Truck has just turned 375000 miles...could it be time for Injectors ? the radiator and fuel hoses are new, batteries new and crank hard, im stumped...
Old May 27, 2013 | 10:42 AM
powerstrokin on ya titis's Avatar
I would deffinatly check out your injectors. could be dirty etc.
Old Jun 2, 2013 | 12:39 AM
4x4manonbroke's Avatar
I would say its fuel shut off switch or something in the pump gone haywire...... only a few things that control fuel and rate of fuel ....start with the obvious .. filters and such... just in case .. maybe disconnect the fuel line at the fuel/water seperator and use an electric pump .... to make sure there isnt something going on in the supply line ... possibly a bad tank switch ... etc.. PM me if you need more direct help
Devon7.3
Sep 27, 2015 10:35 PM
Dye Guardian
Aug 1, 2015 01:28 PM
MrMoose
Mar 15, 2015 06:05 PM
tumble72
8
Nov 27, 2014 10:31 PM
Oct 24, 2014 04:40 AM
