05 ford 6.0 ect and eot acting weird ???
Old May 13, 2013 | 01:07 PM
Josh Chretien's Avatar
Default 05 ford 6.0 ect and eot acting weird ???
hey i have a 05 ford 6.0 dually crew cab short box on 35 with a 6 speed standard my ect are around 190 to 194 and my eot are pretty close to that in town but when on the high way go 7 to 10 out of that i always thought when something was wrong the ect get hotter then the oil temps i just did a egr delete and new oil cooler and hpop stc fitting up grade in the past 1 mouth and new t stat any ideas no tune on it btw
Old May 13, 2013 | 02:36 PM
bobfbigman's Avatar
The oil temp will always be the hotter of th 2 once it is warmed up, the cooler uses engine coolant to cool the oil, without the oil cooler oil temps could get to 250+deg. the magic number is 15 deg. the oil should never get 15 deg. above coolant once it is at operating temps. Make sure you add a coolant filter to your truck to prevent your oil cooler from getting clogged again, because it will without the coolant filter.
Old May 13, 2013 | 08:46 PM
i have a coolant filter on it. but shouldnt they be closer, like 2 to 3 different ? not like 10 to 15 i thought 15 was pretty much unsafe ?
Old May 14, 2013 | 03:42 PM
Curry's Avatar
To be honest it all depends on weather, road conditions, how you drive, how long you have been driving. Ive had both of mine sit around 180-185 on a 2 hour interstate drive. Hit the city and its EOT 200ish ECT 186ish. Then fluctuate back down to 180. Once your truck gets warmed up keep it running, pop the hood and see if the top of the coolant filter is hot. If it is coolant is still flowing.
Old May 16, 2013 | 03:52 PM
ok thanks guys for the info
