No fault but still doesn't run
Old May 12, 2013 | 06:26 PM
MD 91's Avatar
Default No fault but still doesn't run
No run and no fault
So I'm looking at a 99 2wd auto with recent transwork new tires and a new lift pump the owner says it was driving down he highway and died then he had it towed to his house and there it has sat for the last 6 months batteries are dead as can be so I put other batteries in it to get it to crank. When I hook up a scanner there are no faults to read even after cranking ( I was hoping for something) so now I have a truck that I know ran like a champ right up till I didn't ( like most) but have no direction for trouble shooting. I would like to say its the injection pump since the lift pump was recently replaced but have no solid evidence pointing that direction otherwise. Any thing I can test? Wil a truck start and idle even with a bad tps? any help is appreciated
Old May 12, 2013 | 10:33 PM
Bryce's Avatar
Are you getting fuel to the injectors?
Old May 17, 2013 | 06:43 PM
2002Cummins's Avatar
My truck did that. I ended up cracking a couple injection lines open and bled them. In a couple minutes the truck was running again. No codes, you can crank all day but truck will never start until air is out of the lines.
Old May 17, 2013 | 06:53 PM
mysterync's Avatar
Originally Posted by MD 91
No run and no fault
Bleed the system and then if its still not starting standalone the injection pump to rule out possible ecm/pcm issues before even considering pump replacement.
vin_diesel
Mar 1, 2016 01:43 PM
rusmis91
Chevy/GMC Duramax 04.5-05 LLY
Aug 6, 2015 04:44 AM
rick-64
Mar 19, 2015 07:59 PM
clarthom
8
Mar 5, 2015 07:27 PM
wvwelder89
Nov 20, 2014 10:26 AM
