2002 Edge Comp Wiring Help
Old May 12, 2013 | 11:16 AM
CoryChoate's Avatar
Default 2002 Edge Comp Wiring Help
Hey guys,
I bought a comp, and the previous user had it set up for his 01 with the 01 connectors on it. I guess this is the early version of the comp box because the new ones come with adapters for the 02 that use the 01 connectors, while the early ones did not. The 02 connectors were loose in the box. I cut the 01 connectors off and now need to attach the 02 connectors, but I'm having a problem.
On top is the 01 connector, and on bottom is the 02 connector. As you can see, the 01 connector has 3 wires going to it from the lead, a green white and black (Or brown?) and the 02 connector only has 2 bare leads going to it. Anyone have any idea how the 02 connector is supposed to be hooked up?
Thanks much,
Cory
Old May 12, 2013 | 04:28 PM
BarryB's Avatar
What I would do is put the 01 connectors back onto the harness, and then find the 02 map sensor adapter. They can be gotten from edge. Then it is just plug and play. it uses the 01 map sensor plug and converts it to 02 plug. Here is a pic of said adapter. That way there isn't any guessing. You burn up the module, then its going to cost 150 bucks + shipping to get it repaired.
RexShoppe
Price Quote - Request A Price
Nov 23, 2015 02:38 PM
Rusted Dragon
Feb 27, 2015 09:46 PM
scottxmorris
Feb 6, 2015 05:33 AM
FF131
Jan 21, 2015 11:37 AM
scottxmorris
Dec 31, 2014 03:20 PM
