Transmisson hunting
Old May 11, 2013 | 08:51 PM
kgess's Avatar
Default Transmisson hunting
I have a 1999 2500 w/110k miles and the transmisson keeps shifting on a slight grade at slower speeds. The shop is changing the fluid and filter, he scanned the xmission and found no codes. Should I install the APPS noise isolator from DB???? does any one have a thoughts on this problem....
Old May 13, 2013 | 03:30 PM
diesel life's Avatar
when my stock tranny started doing that with around 130k it was the governor pressure silenoid changed it out and was good to go.... ive since toasted that tranny though....
Old May 13, 2013 | 09:48 PM
o00otii's Avatar
Is the trans shifting between gears or is the torque converter jumping between locked and unlocked? The TQ hunting issue is well documented and what I believe those noise isolators are for. They take out the AC noise that a potentially bad alternator sends though the electronics.
Old May 16, 2013 | 08:10 PM
Bruce24Valver's Avatar
I had the same issue with my 47re, if you go on ats's website, they have detailed instructions for a rewire, took me about 15 minutes, problem solved, shifts super smooth now. Just an idear.
gunman41mag
The Sportsmen's Lounge
Sep 22, 2015 07:10 AM
carid
Diesel Bombers Sponsors
Feb 2, 2015 09:24 AM
flyers.nhl
Oct 31, 2014 04:33 AM
