intermitent ticking in 04.5 cummins help please.
Old May 9, 2013 | 11:25 PM
5.9inline2008's Avatar
Default intermitent ticking in 04.5 cummins help please.
hey guys
I have a 2004.5 cummins i bought a few months ago and ever sence the truck has had a slight intermittent tick that randomly comes and goes once the truck is warmed up good. Aside from the noise the truck has plenty of power and runs smooth. Also if you rev the truck up only 100 to 200 rpm the soise faids away. The truck is bone stock and has 120k miles on it. I have had my truck to many local mechanics and none of them have helped. Some of the mechanics told me it was normal for these trucks and that they simply clatered like that, once engine warmed up. Also had a guy tell me the truck had a bad lifter. Then I had one almost guarentee me the noise was bad injectors, so i took a gamble and went out like a dumby and replaced every single injector, to find that 6 hrs and 2000+ dollars later it had fixed nothing.
Sooo at this point i am lost, I have no where else to turn but you guys, because evidently no one out my way knows what the heck they are talking abought . Any help woul be greatly appreciated.
Old May 10, 2013 | 04:41 AM
BBD Tech Support's Avatar
Sorry I can't help without hearing in person. Suck about $2000 in injectors
Old May 10, 2013 | 08:22 AM
dangerous1965's Avatar
Put a 2 micron filter inline before the CP3 to make them last! Don't worry about the noise it is a bunch of possible things even oil type and filter type could make it happen.
You can run the valves wouldn't hurt probably never been done! I would say it was a lifter since it goes away when warmed up! Now go get a Smarty and tune it!
Old May 11, 2013 | 12:01 AM
yea as far as the smarty, its in the plans, along with some other goodies but if this were a lifter problem would it be a typical noise when cold or warm and would it be this random. because the noise dosent start till the truck warms up all the way.
i can post a video later if that would help?
heres he vid of my truck.
Last edited by 5.9inline2008; May 11, 2013 at 12:01 AM. Reason: Automerged Doublepost
Old May 11, 2013 | 06:00 PM
That is very metallic sounding I wonder if you have a loose valve seat??! Did you want to pull the head for any reason? I hope I'm wrong others will give opinions but if you drop that valve then you have to rebuild the whole thing! Right now if you pull the head just the head will need repair. Run it with the valve cover off use a hose to listen to each cylinder you will really hear it thru the hose! Also see if any of the valves sit higher or lower than the rest.
Old May 11, 2013 | 07:27 PM
Well i hope its not the head either, however it dosent realy make sence that it would be the head being that its so speratic and unpredictable pluss the sound goes away with more rpm. I would think if it were the head or any thing other than lifter the sound would get worse with mor rpm?
Old May 11, 2013 | 11:48 PM
Do the test we'll go from there!
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
ryank 199
May 14, 2015 06:41 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
