parked the cummins for 12 hours now it wont start
Old May 8, 2013 | 11:39 PM
1stgencumminsdenis's Avatar
Default parked the cummins for 12 hours now it wont start
Went outside to start my truck,turned the key to on position the wait to start light was real dim and when i tried starting it nothing the battery gauge just drops andnothing happens when i try to boost it with my dads 24v the starter relay clicks and the starter barley turned over. Next i swaped the starter relay and the ac relay and absolutly nothing not even a click, even when boosted... in need of some serious help this is my daily driver
Old May 9, 2013 | 09:10 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
check to see if you have a bad (shorted out) battery.
Old May 9, 2013 | 11:18 AM
I unhooked both battery posts and cleaned them the ground goes stright to the engine so i dont think is that
Like its like my batter has a massive load on it when i turn the key to on the lights start dimming even after the wait to start light turns off
Last edited by 1stgencumminsdenis; May 9, 2013 at 11:18 AM. Reason: Automerged Doublepost
Old May 11, 2013 | 07:32 PM
geddy's uncle's Avatar
when the other guy mentioned "shorted battery", he didn't mean an external short somewhere in your truck wiring, he actually meant internally, inside the battery. It's pretty common with the classic rectangular lead/acid situation. what happens is that every time you discharge and recharge, a small amount of plate material detaches from the plates and falls to the bottom of the cell. As the months and years go by, that stuff builds up in the bottom of the battery until the pile of stuff (lead sulfate) actually makes contact with the plates. Ba-da-bing! Shorted battery. Dead cell. If it's only one cell, you go from 13.2 to 11VDC. Your truck might not notice that. Time goes on. Another cell fails by the same process. 8.8VDC. You're unlikely to start the truck, but, if it does, you're thinking "somehow, just didn't feel the same". If you can go along on 2 dead cells, that will give you the time to short a third one. 6.6VDC. It's hopeless, and you're NOT going to start it. You might not even get a proper jumpstart with your own battery connected, because the "good" vehicle will just be passing electricity thru your battery, instead of yours accepting a charge.
Rusher48
Jul 2, 2020 08:39 AM
mcclusk
Feb 21, 2015 09:50 PM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
elkmaniac
Oct 29, 2014 07:01 PM
