my B-day present.
Old May 7, 2013 | 11:24 AM
cummins_guy's Avatar
Default my B-day present.
alot of cutting to make them fit, but I got them on..
Old May 7, 2013 | 11:27 AM
I also have one set for sale.
6 wheels
4 adapters
40 lug nuts
32 lug nuts
no center caps
Old May 7, 2013 | 02:41 PM
1993firstgennewbie's Avatar
looks sweet but I think you are going to regret putting them on. These trucks cant handle all that weight spinning. my brother has a 03 wit 38" semi tires and his front end is trashed it gets death wobble like a mother F@cker its pretty freaking scary at 70mph. if you plan on keeping them you better be planning on beefing up your frontend is all Im trying to say
Old May 9, 2013 | 04:42 PM
peckens's Avatar
steering gear will also put a lot more stress on the frame, be ready for cracks.
Old May 21, 2013 | 11:01 AM
if you take care of your truck, then your truck will last, these wheels do not weigh anymore than a 19" with 33" on them, the reasone for most failures is people who do things with there trucks that they should not be doing in the first place without updating the suspension and the drive link.
I had to update springs and struts
HD SPRINGS
BELSTEIN STRUTS
NEW BALL JOINTS (UPPER AND LOWER 4,000 LBS AXLES)
NEW TIRE RODS (4,000 LBS)
I am only going on highway and around town, not jumping the truck or trynig to race it, this is for my enjoyment only, if I wanted to go off road, I would build my truck to do so.
for 1993 first gen newbies friend, the new truck are put together with non greasable joints, (I'm probable going to open a can of worms) non greasable are junk, especially if you are going to upgrade your wheels, every truck I have owened has had greasable joints installed and thrown away the non type, your friend should replace his with greasable.
I have had many truck with very large tires, when I start running into problems with steering and joints, when I start to go to high, I do appreciate the opinions, but I have done this for a long time, if you replace your parts with cheap stuff, then......... replace with good parts,
I have added some pics
the one pics show all new parts with my grease gun that leaks, I didnt wipe the grease off yet (just incase someone thinks I over greased I didnt, the dang grease gun leaks from every point, you should see my hands when I'm done, my wife wont let me in the house.
for death wobble, that is because something is not function properly, your friend needs to get that fixed, always remeber this, the truck did not leave the factory like that, it means that somewhere in there some thing is going wrong, whats wrong, I'm not sure, everyone always has a write up on what they did, but every truck is differnt, I can say for my truck, it had a small bounce, and when I was replacing struts and springs, the lower ball joints were distroyed, they were never replaced since factory, since I replaced everything under there, I have had no issues and the ride is nice, wife does not like to ride in it, but I this is my 3rd child (the truck)
Attached Thumbnails my B-day present.-new-spring-strut.jpg   my B-day present.-truck-new-height.jpg
Old May 21, 2013 | 11:09 AM
tried to delete.
Old May 21, 2013 | 11:10 AM
trying to delete, my computer is acting wierd.
Old May 26, 2013 | 03:12 AM
dezeldoc's Avatar
Umm them be shocks not struts.
Old May 30, 2013 | 02:16 PM
I call them a strut because of the spring, thank you for your correction.
update on how she handles
she is a little rough but I am going to try letting some air out and keep driving in till I find a sweet spot, so far running 55 or 60 she is really smooth, she does like to follow all the ruts and dips in the road, I hopeing the sway bars will cure that, I found some brimbo rotors that I will be putting on and replacing the bearings as well.
so far so good
tbreddiesel
Thoroughbred Diesel
Oct 2, 2015 02:56 PM
tbreddiesel
Diesel Related Events
Oct 2, 2015 02:55 PM
May 6, 2015 03:20 PM
Nov 11, 2014 04:10 PM
tbreddiesel
Thoroughbred Diesel
Nov 11, 2014 07:53 AM
