help
Old May 7, 2013 | 12:36 AM
jdubb623's Avatar
Default help
I have a 2001 dodge cummins with an intake, exhaust, edge ez box and a raptor 100 lift pump. It started acting like it was running out of fuel when I let off the peddle. So I stepped back on the peddle to keep it running, this happened about 3 times then as I was pulling into my driveway it died and now it wont start. I have checked for air in the fuel lines, checked the fuel filter and also tested the fuel pressure from the raptor and it read zero. Do I have a bad lift pump ?
Old May 7, 2013 | 04:12 AM
97cummins's Avatar
yea,it sounds like the lp is doa. Are you getting any codes?
Are you getting any fuel through the lines?
