Clutch problem
Old May 5, 2013 | 05:10 PM
Oil Igniter's Avatar
Default Clutch problem
Greetings, The truck got a new clutch this weekend. Centerforce dual friction, flywheel resurfaced, new throwout bearings (identical to factory one), new pilot bushing, new input shaft seal for trans, new front output seal for transfer case. All went really smooth until i expected the clutch to disengage. The truck was very difficult to get into gear. Thought it could be the hydraulics so the whole unit was replaced. Did not solve the issue. The trans is still very tough to get into gear and thats with the clutch on the floor fully depressed. The pedal feels solid but does nothing till and and inch from the floor. While driving the clutch is fully engaged if you even think of letting off the floor with the pedal and still a hard shift while driving. With the hydros out it doesnt seem there is much slack at all with the pivot arm. Also the clutch seems to chatter. I have run centerforce in my camaro and they have been awesome. Long winded I lknow but any thoughts or suggestions would help. Thanks
Old May 6, 2013 | 01:29 AM
97cummins's Avatar
The only thing that i can think of is one of the clutch discs could be put in on the wrong side.
Old May 6, 2013 | 06:22 PM
I see how that could happen;however, this is a single disc clutch. I was very careful to match the side of the disc that says "Flywheel side" to the flywheel. I appreciate the input though. I called centerforce and they said I should have replaced the flywheel. I have done a few clutches before by resurfacing and all of them were fine. Anybody had poor luck with resurfacing? A friend of mine has had his flywheel turned three times and has no issues.
Old May 6, 2013 | 08:05 PM
BarryB's Avatar
I have heard of puttings shims Not sure exactly where maybe behind the flywheels where the crank bolts. To actually push the flywheel back the same distance that was removed when resurfaced. Sounds crazy I know, but sometimes .010 can make a big difference. Id say its definitely worth a better look on that matter.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Turbo67
Jul 25, 2015 02:26 PM
muderxtreme
Jan 8, 2015 01:16 AM
Wyocumins
Oct 19, 2014 09:34 PM
