oil leak still
Old May 5, 2013 | 11:41 AM
MBFD 592's Avatar
Default oil leak still
I changed pushrod cover gasket, front gear cover gasket, and the front crankshaft seal. still have oil leaking from driver side of the engine. block looks dry under pushrod cover gasket. I can see oil on the side of the block below that. can't figure out were. what am I missing? would like to know before I start ripping this thing apart again.
Old May 5, 2013 | 10:10 PM
Bryce's Avatar
Might be coming from the vacuum pump. Check where the power steering pump shaft goes into the vacuum pump for oil.
Old May 6, 2013 | 08:14 AM
MillerBoyzDiesel's Avatar
Have you checked Valve cover gasket or head gasket?
Old May 7, 2013 | 08:30 PM
redneck_cummins's Avatar
x2 on the vacuum pump.
Old May 8, 2013 | 03:06 PM
tiremann9669's Avatar
X3 vacum pump seal
cummins Pride
Sep 28, 2015 12:11 PM
BKID
Jul 25, 2015 07:59 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
