Help! Shudder/Bucking in Overdrive
Old May 5, 2013 | 11:18 AM
03RaptorCV's Avatar
Default Help! Shudder/Bucking in Overdrive
I need advice on a major studder in OD and a slight up and down idle. Just got done installing injectors that were rebuilt to 155cc by Warren Diesel after hearing nothing but good things. They claim that my issue is more than likely an injector not sealing properly. I am somewhat skeptical about their diagnosis. Also, I know a lot of you will tell me that I should have only gone with OEM replacements or Alliant injectors, but since mine were doing so well prior to the solenoids/coils getting fried I thought having them rebuilt was worth a shot.
I torqued them down to 30 ft/lbs. They recommend 32 ft/lbs. I did not clean out the injector cups with a brush or anything like that, but I did blow out the injector hold down bolt holes. They said if my injectors were sticking that it would show up during cold starts and not just in OD.
Like I said my injectors were all doing great prior to my FICM frying and taking several out on the electrical side with it. Now after having them repaired and reinstalling them this issue has showed up. The truck doesn't feel like it has quite as much power as it did before the problem. Plus while I was getting my FICM rebuilt I got the ATLAS 40 tune on it and also had my ECM strategy rolled back to a VXCF4 stategy so that along with 155cc injectors with stock nozzles you would think I'd have more power. Also, why would my injectors suddenly be sticking?
What should I do to properly diagnose my problem? Warren Diesel said I will have to pull injectors until I find the one that is leaking past the copper gasket. I have an AE scan tool. Should I do a Power Balance test? I will probably do a buzz test while I am at it, but don't forsee that showing any issues. Any advice is greatly appreciated.
Old May 5, 2013 | 12:02 PM
bobfbigman's Avatar
definately sound like a dead injector to me, it probably gets real bad when going up hills too.. did they install new spool valves/the parts that stick/ when they rebuilt them. this is not stiction this is a dead injector. a ballance test should definately show where the problem is. 32ftlbs seems like alot of torque, Ford recommends 24 which is a little too lite but torqueing them to 28 is fine.
Old May 5, 2013 | 12:12 PM
03RaptorCV's Avatar
Thanks Bob. I'll go ahead and do a buzz test and power balance test and let you know what I find.
Old May 6, 2013 | 08:15 PM
03RaptorCV's Avatar
It ended up being an injector connector that was disconnected. I must not have got it popped on good when I put it back together.
Old May 6, 2013 | 11:11 PM
bobfbigman's Avatar
that would definately cause a dead injector, glad it was simple and free
Old Aug 20, 2013 | 03:38 AM
DirtyDiesel613's Avatar
Old thread, I know. You are the only one I can come across on the forum that runs the exact WD Injectors I want. How do you like them so far?
450r racer
8
Dec 21, 2015 06:42 PM
FF131
9
Mar 26, 2015 07:06 AM
Legato
Jan 23, 2015 09:15 PM
thetrot
Jan 15, 2015 09:51 PM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
