hard starting
Old May 4, 2013 | 02:45 PM
pokesalad's Avatar
Default hard starting
My truck has a hard time starting after it sits a while. I just recently replaced the return valve on the injector pump but that did not help. after you start it up it will start easy after that. I do notice that my fuel pressure quickly goes to zero once I shut it off. Should it keep some kind of pressure to the pump after you shut it off?
Old May 6, 2013 | 01:34 AM
97cummins's Avatar
I don't think it keeps fuel pressure after the motor is shut off.
Old May 6, 2013 | 08:11 AM
MillerBoyzDiesel's Avatar
Fuel tube o rings are most likely bad.
Old May 6, 2013 | 10:32 AM
H.R.D's Avatar
Check the fuel drain manifold on the back of the head on the driver's side. It loosens up overtime and can create these symptoms.
Number 9 on the PDF diagram.
Old May 8, 2013 | 08:59 PM
hulse09's Avatar
im having the same probablem!! i just rebult the motor. new cross over tube o-rings and i made sure i had the return line tight on my head!! if any one could help us it would be nice. its diveing me nuts!!!
Old May 8, 2013 | 10:56 PM
Bryce's Avatar
Try disconnecting power to the lift pump before a cold start. If it starts easier then the diaphragm in the vp44 is damaged. Dont drive it with the lift pump disconnected.
Excursion73
Oct 27, 2015 05:21 PM
Easton18t
Jul 30, 2015 02:06 PM
joker55
May 15, 2015 10:24 AM
gwmeyer
May 14, 2015 12:46 PM
91 7three
Jan 7, 2015 09:37 AM
