Deadhead HPOP
Old May 4, 2013 | 12:23 AM
smoran22's Avatar
Question Deadhead HPOP
Hey y'all,
I was wondering if you have any easy ways to deadhead the HPOP. Can I just unplug the FICM, put 12V to the IPR and crank away and use the ICP reading and my gauge, or is there a specific way I have to do it?
Thanks!
Old May 4, 2013 | 03:44 PM
bobfbigman's Avatar
that would work, my questin is why? think your pump is dead?
also make sure you watch your guage, I wouldn't let it go over 4000psi, might hurt something.
Old May 4, 2013 | 06:13 PM
smoran22's Avatar
its maxing out my gauge above 4000 psi. so the pump is good... im gunna throw an ipr at it and see if that the issue.
The issue is a hard start when it sits more than 10 hours. It'll start and die, start and die, start and die... FICM was repaired, engine rebuilt, new hg's, studs, 1 new head, all new bearings, new Oil Pressure Regulator, aftermarket HFCM, Blue spring upgrade, new injectors, but i totally spaced out the IPR. PCM and FIcM are at current revisions and im running out of options!
bajahigh
Mar 24, 2015 10:12 PM
BlackOut96
94-98 7.3L Performance
Dec 11, 2014 07:24 PM
blakec
Nov 29, 2014 10:48 PM
