E4OD Rpm's Too High In O/D
Old May 3, 2013 | 10:08 AM
Sandman8105's Avatar
Default E4OD Rpm's Too High In O/D
I installed new fluid, a new filter, and a reman. solenoid pack (due to the fact that the old one was getting fluid in the connector). After this, when it shifts from 3rd to o/d, the rpm's remain VERY high. Since this, I have replaced the solenoid pack again and still, the same thing. I have another pack but, I was looking for some in-put before I just go thru this all over again. Give me a little bit and I'll throw my Innova 3140 on it and tell ya'll the codes. Yes, the o/d light is flashing. Also, after I replaced the packs, I did erase the dtc's so the computer would hopefully recognise the fix but, apparently I haven't fixed the problem. Any help would be appreciated. Thanks everyone!
Jeff Simpson
Old May 4, 2013 | 08:03 PM
<bump>
Old May 5, 2013 | 11:54 AM
POWER-STRUCK's Avatar
check the brake switch, it may be applying voltage and keeping the torque converter unlocked
Old May 17, 2013 | 09:26 AM
Where is it located?
Old May 20, 2013 | 07:51 PM
<bump>
Old May 21, 2013 | 07:10 AM
on the brake pedal
Old May 21, 2013 | 07:26 PM
Ok. Thanks. Could it also possibly be a broken od retaining spring?
john grossman
10
Jan 12, 2019 08:58 PM
Jake9473
Jul 22, 2018 08:19 AM
Blackdog15
May 20, 2015 10:49 PM
robbyS
Apr 16, 2015 02:22 PM
gvanevans
Dec 26, 2014 04:39 PM
