new to the 6.2
Old May 2, 2013 | 07:14 PM
slitko's Avatar
Default new to the 6.2
hey guys i have once again added another vehicle to my diesel collection just want to know what all u guys have done for power ...........also on another note if i start in first well second i guess if u count granny gear as first the truck jumps and shakes bad any ideas oh and heres a pic of the ol girl
Old May 3, 2013 | 12:29 AM
MontanaTechPetroleum's Avatar
There's not much for power on the 6.2/6.5 that you can really do. For the 6.2 the biggest thing you can do is add a turbo and turn up the fuel pump. Not really much else you can do.
As for the starting off issue, your clutch might be wearing out or it simply doesn't have enough power to start outside of the granny. 6.2s only have around 130 hp and 250 or so ft/lbs of torque, not really sufficient for a 3/4 ton pickup. Does it jump and shake when you use the granny?
Old May 3, 2013 | 05:54 PM
slitko's Avatar
yes but very little
my truck is the 6.2 4 speed with a np208 is the tranny the sm465?
Old May 6, 2013 | 11:13 PM
Could be a nv4500, not really sure when they switched to it.
Old May 17, 2013 | 05:09 AM
RivervalleyJohn's Avatar
Oil on the clutch can do this.
Old Jun 9, 2013 | 02:29 PM
slitko's Avatar
nv4500 is a 5 speed is it not?
Old Jun 9, 2013 | 06:16 PM
detroitdiesel idi's Avatar
Yea nv4500 is a 5 speed. its most likely the sm465.you can always call a chevy dealer and give them your vin# and theylle tell u everything about the truck
Nv4500 wasnt in gm trucks till 1992
Last edited by detroitdiesel idi; Jun 9, 2013 at 06:16 PM. Reason: Automerged Doublepost
Old Jun 9, 2013 | 08:10 PM
SRR's Avatar
SRR
Check your carrier bearing, your drive shaft might be hopping around.
Old Jul 9, 2013 | 03:26 AM
puddlestomper's Avatar
Or broken tranny or engine mount.
NSmachine44
Aug 16, 2015 09:25 PM
MIBoondocker
Jun 20, 2015 11:56 PM
jedder21
Mar 7, 2015 09:47 PM
Caveman94
Dec 8, 2014 12:21 PM
jdcarter
Nov 29, 2014 11:31 AM
