starting problem
Old May 2, 2013 | 08:35 AM
ruben24's Avatar
Default starting problem
Hey guys im new to this but i have a problem with 06 cummins i use starting fluid for the first start of the day cuz it wont start but after that starts on it own can someone plz help
Old May 9, 2013 | 09:25 AM
ruben24's Avatar
Need help guys my 06 cummins wont start without ether for the first start of the day after that starts on it own
Old May 9, 2013 | 11:48 AM
H.R.D's Avatar
Unplug the FCA harness from the CP3 and see if it helps you. Using ether is strongly discouraged in newer diesels.
You may have created an ether baby.
MillerBoyzDiesel's Avatar
Check banjo fitting seals on back of head. Check fuel tube orings. Could be injector/s going out. Id check those two things first though.
Old May 10, 2013 | 08:24 AM
ruben24's Avatar
Ill try it thanks So just unplug it for how long
Ok guys i need some help my 06 cummins wont start without ether if i dont use it my truck drain the batteries fast n if i use ether starts good n all day too could it just be my batteries
Old May 10, 2013 | 11:24 AM
H.R.D's Avatar
Unplug it then try to start if for the first start of the day and see if it helps. If it doesn't then plug it back in. If it does help you FCA may be going out.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jmohr52
Nov 2, 2014 08:55 PM
