Oil Filter Standpipe question
Old May 1, 2013 | 04:15 AM
Ozz's Avatar
Ozz
Default Oil Filter Standpipe question
I am just starting to put my 03 6 liter SD back together as I have done the EGR delete, New oil cooler, coolant filtration kit, blue spring kit and FICM repair plus an atlas tune.
When I pulled my oil filter housing, my stand pipe did not have a spring on the upper portion of the stand pipe as I see in all of the videos on youtube. Well, I got a wild hair up my butt and decided to put my leveling kit on today. I found a spring under my truck?????? I think it may go to my oil filter stand pipe, but I"m not sure. It for sure did not have the spring on it when I pulled my filter off the truck and it's too small, or it seems too small to fit over the stand pipe, but it easily fits inside the stand pipe?????? It's a shinny light brass color and about as long as my index finger.
Can anyone help me?
Old May 1, 2013 | 09:39 AM
MillerBoyzDiesel's Avatar
there is a spring that sits inside at the top of the filter tower. Ive seen them missing too, doesn't seem to change anything. Theyre not near as long as a finger tho. Is it real small like a fpr spring?
Old May 1, 2013 | 11:58 AM
Ozz's Avatar
Ozz
OK, I figured it out... I was kind of stressed about it, then I realized where my mystery spring came from. I broke the Air intake resistance sensor when I took off my intake kit. That spring looks like it can fit in the oil standpipe..nope Glad I figured it out. Back to the grind
Thanks for the help!
Old May 1, 2013 | 05:12 PM
bobfbigman's Avatar
Just make sure you have the plunger in the top of that standpipe, it is a bypass for the filter system and if it is missing then it can cause issues. Just use your finger and push down on the center of standpipe and you will see the plunger work.not the fuel pressure spring is it ??
Old May 1, 2013 | 10:53 PM
Ozz's Avatar
Ozz
NO, it was the spring inside the air restriction filter sensor.
Old May 2, 2013 | 05:01 PM
bobfbigman's Avatar
gotya, those things are always in the way, finnally did away with mine
Old May 20, 2013 | 05:26 PM
STLPerformance's Avatar
only use motorcraft oil filters, anything else will damage your truck do the research watch the youtube videos motorcraft oil filters is all you should run in your truck !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1stgenSWB
Aug 13, 2015 12:19 AM
soco
Jul 27, 2015 06:06 PM
helton87
For Sale
Jun 3, 2015 02:36 PM
Bob V
Apr 6, 2015 11:02 PM
Moparpower440
Jan 24, 2015 06:58 PM
