Ecm/pcm issue?
Old Apr 30, 2013 | 10:17 PM
kf6cmp's Avatar
Default Ecm/pcm issue?
I have a problome with my Truck. I keep getting a check engine light p121. Now I know this has to to with the throttle position sensor . So I reset the trouble code i.e. cleared it. It came back on again. So I went to recalibrate it. Disconected my ground on the batteries and let it sit for a few hours. Then reconected the Batteries and turned key on and did the three slow applications of accelerater peddle. It reset. Now my wait to start light isnt working and after a few hours of driving, my truck threw another code. yep, p121. On the way home from work my speedometer started jumping around and finally just fell to zero. The truck seems to be running fine. After reading a few hours on forums, it seems that the Ecm/pcm could be the issue. Does this seem plossible? I had a simular issue a few months back. My wait to start light stopped working and a few weeks later my starter failed, Cheap Napa starter, and after replacing starter and reconecting my batteries, a day or so of disconect, my wait to start light worked again.
Old May 2, 2013 | 12:54 AM
RamHORN's Avatar
any dead pedal or power loss while driving with the code active?
Old May 2, 2013 | 07:05 AM
mysterync's Avatar
Before you call it bad computer you should find a qualified tech to diagnose the truck. No reason to throw parts at a problem and there is absolutely no way anyone on a forum can tell you of its bad. You would have to do atleast an hour of extensive testing.
Old May 2, 2013 | 07:31 AM
MillerBoyzDiesel's Avatar
Have you tried readjusting your throttle position sensor? Scan tool would come in handy for this or you can do it with a dvom.
Old May 2, 2013 | 08:44 AM
mysterync's Avatar
I've found that a scan tool and dvom don't offer a high enough refresh rate to see glitches in tps circuits. You could look at it for hours and not see the glitch that you could see with a DSO. Of course powers and grounds should be checked before replacing apps. And I've found that regrounding the pcm helps quite a bit with issues like this.
Old May 2, 2013 | 09:34 AM
I don't think the apps is necessarily bad. Maybe just worn. If the code is p0121, that's showing a volts mismatch with idle validation switch. Wouldn't actually be looking for sweep values just at rest value to start with then go from there. It would be nice to see what the voltage is with pedal at rest to see if it is above or below spec.
Old May 2, 2013 | 10:40 AM
mysterync's Avatar
Right, but if you look at when those pids are monitored you'll see my reasoning for watching posistion values as well.
Old May 2, 2013 | 11:01 AM
I completely agree with you on watching the sweep and doing so with a scope. Im just saying start by a quick check and go from there.
Dec 10, 2019 10:10 AM
Diesel_Daddy6.0
Nov 12, 2015 09:33 PM
Cummins_Power_13
Feb 4, 2015 09:55 AM
Oct 23, 2014 08:10 AM
Oct 8, 2014 08:10 AM
