vp44 help
Old Apr 30, 2013 | 05:21 PM
Cumminnotstroking's Avatar
Default need help fast....injector pump help
VP44 finnally went out. Left me on the side of the road. Its throwing the code p1688....not good. its my understanding that there is nothing else to do but replace it. So i guess the question is what kind of pump should i go with ? been thinking about the bd high performance vp44. wondered if anybody has one or has a better option without spending the 4000 on a p-pump conversion. thanks
Old May 1, 2013 | 07:15 AM
SRTcummins's Avatar
If i recall a p-pump conversion is only ~2250. If your labor is done by your self.
Old May 1, 2013 | 08:53 AM
I think trying the conversion myself might be a little more then I can handle. How do you like your bd vp44
Old May 1, 2013 | 06:11 PM
H.R.D's Avatar
P0216 is usually the VP death code.
Here is some info on how to diagnose your VP.
http://articles.mopar1973man.com/ind...=59&Itemid=107
Old May 1, 2013 | 07:33 PM
I looked at a forum from blue chip diesel and they seemed to have a really good link on how to diagnose the fuel system. I would actually recommend everyone to take a look at it if your having any problems. It's very detailed and has a lot of information. It said that the 216 isn't as bad as everyone thinks and only tells you the Injection Pump can’t attain full timing advance to provide good fuel mileage and power and that the 2 worst codes are 1688 and 1689. What are other people's thought ????
Actually if you read the link you sent me it tells you the exact same thing. The 216 code doesn't mean you need to replace the IP
Last edited by Cumminnotstroking; May 1, 2013 at 07:33 PM. Reason: Automerged Doublepost
Old May 1, 2013 | 09:28 PM
H.R.D's Avatar
Yes that pdf is the info from blue chip. I didn't say the P0216 code means you have to replace the IP, I said it is usually the death code.
Old Jun 27, 2013 | 09:39 PM
Replaced my stock IP with a BD high performance VP44. It made a BIG difference. great power, way better gas milage. Also added a pair of BD 100 HP Injectors while i was in there, can i say black smoke
Old Sep 1, 2013 | 03:08 PM
IbeCummins02's Avatar
Default e check
hey just curious, say I need to replace my vp44 and I get a hot rod vp44 and I don't chip it does anybody know if they pass E check? or should I just p-pump it play it safe?
Old Sep 3, 2013 | 12:15 AM
diesel life's Avatar
is that with or without the pump?? all the kits i have seen are around that schied has one crazy carls has one haisley also has one but not one of em come with the p7100 so thats an extra cost.. just curious to if you have found one with the pump as i have thought about this but im still on my stock vp 186,000 and counting with fingers crossed
Old Sep 3, 2013 | 08:04 AM
jkidd's Avatar
$2250 is expensive these days.
Keep in mind that you lose the dynamic timing that the vp44 offers. you can get a replacement Vp44 for under $1000 from several places. IMO a p-pump swap is better suited for performance applications for those trying to break 600-650HP. you can replace 2x vp44 for less money (once you get a p7100 pump) and the adaptation requires more time.
justinsbeck
Jan 18, 2016 12:15 AM
Dslmech600
Price Quote - Request A Price
Aug 11, 2015 09:39 AM
Big Bill
Mar 19, 2015 11:13 AM
DeLuzGN
Mar 17, 2015 08:08 AM
somarillw
Dec 15, 2014 12:00 AM
