Help figure this out?
Old Apr 30, 2013 | 09:22 AM
Rolling Coal's Avatar
help Help figure this out?
okay so pulled the tranny out drained all the trasnmission fluid and then put it back in filled it back up. now it leaks but not where i can find it. i can see where its landing but can`t figure out where it`s coming from. the lines that i tightned up are tightned up as much as i can stand and that can`t be the problem. i have no idea where its coming from!
Also got ac sorta running good had to replace the black box thou. but now in the passanger floor board its a lagoon! water just pooled there while i was getting my tip put on. could it be a kinked line?
Old Apr 30, 2013 | 10:46 AM
1999stroker's Avatar
Heater core leaking in our dash
Sent from my DROID RAZR
Old Apr 30, 2013 | 01:52 PM
you think so? my cousin has a truck a year older then m e and said it might be a kink in the lline but thanks i`ll check the heater core
Old Apr 30, 2013 | 04:26 PM
Every time I've heard of a wet floorboard its heater core. How is a kinked line gonna cause water to be on your floor? Its kinked nothing gets through it.
Old Apr 30, 2013 | 06:12 PM
blackduck's Avatar
By line I take it you are refering to the condensate drain hose, if it is kinked it will not drain the AC and will overflow onto the floor.
Check where the drain exits to see if water is coming out.
Old Apr 30, 2013 | 09:50 PM
BC847's Avatar
Or the short little hose that drains the condensate pan out the firewall is missing and allowing the condensate to drain into the heater box an onto the floor.
Old May 1, 2013 | 08:57 AM
Okay so will check that today. Also i heard you could get un wanted spray paint off a truck with WD-40. is that true or total bs?
Old May 1, 2013 | 12:26 PM
Sorry my last post shows how much I know about 1st gens :banghead:
Old May 1, 2013 | 01:57 PM
well are you being sarcastic or ?
Old May 1, 2013 | 03:58 PM
No I wasn't. Lol.
