6.0 intake noise
Old Apr 25, 2013 | 08:57 PM
nikkos17's Avatar
Default 6.0 intake noise
So i was getting gravel today and the guy asked if i had a cracked intercooler boot from the noise coming from intake. I checked them and they seem fine, possible they have a pin hole. Ive been reading that it could be a push rod so now im freaking out cause i spent all my money haveing headstuds and a new turbo put on. Any help would be great!!
Thanks
Old Apr 25, 2013 | 11:05 PM
MillerBoyzDiesel's Avatar
whats the noise sound like?
Old Apr 26, 2013 | 08:21 AM
nikkos17's Avatar
just sounds like woop woop woop i thought it was just from having bigger intake.
Old Apr 26, 2013 | 08:49 AM
if its not popping through the intake id rule out a valve train issue. So it sounds like a howl?
Old Apr 26, 2013 | 09:00 AM
nikkos17's Avatar
is there a way to test for a push rod? the truck runs like a top?! im so lost
Old Apr 26, 2013 | 09:23 AM
usually with a bent pushrod/broken rocker arm it wont run right and can pop like a back fire through the intake.
Old Apr 26, 2013 | 09:30 AM
nikkos17's Avatar
it deffinately runs fine so should i just stop being paranoid?
Old Apr 26, 2013 | 10:10 AM
haha yes but, you may want to have truck looked at if turbo is howling.
Old Apr 26, 2013 | 11:09 AM
nikkos17's Avatar
alright. thanks so much i always check here when i have questions and its always you and that mdub guy with most knowlege
Old Apr 26, 2013 | 12:40 PM
HeavyAssault's Avatar
I had a sound like woop womp womp woop yaggah woop. I found a cracked cold side intercooler pipe. Swapped it out for a 2003 metal pipe for cheap.
