Need help with adding lift
Old Apr 25, 2013 | 06:00 PM
Stroker815's Avatar
Default Need help with adding lift
I currently have a 4 inch suspension lift on my 05 f250. What would i have to do to upgrade it to a 6 inch suspension lift? would i have to change the whole lift or just bigger springs in front and blocks in the back?
Old Apr 25, 2013 | 06:41 PM
HeavyAssault's Avatar
A front spacer and a set of blocks would work. Your shocks could be upgraded to some Bilsteins for about $300 that would be perfect for the 6" lift. Otherwise the shocks can work, but don't go extreme off-road.
Old Apr 25, 2013 | 06:55 PM
Stroker815's Avatar
what do you mean by a front spacer? and so all id need is spacer, blocks, and new front/rear shocks?
what about the coil springs in the front?
Last edited by Stroker815; Apr 25, 2013 at 06:55 PM. Reason: Automerged Doublepost
Old Apr 25, 2013 | 07:01 PM
Curry's Avatar
Spacer for the coil. Id rather have a coil for the new lift and just make or buy some blocks for the rear and hopefully you have some slack in all your lines.
Old Apr 25, 2013 | 07:11 PM
Stroker815's Avatar
Would it cause problems having just the spacers? or ride rougher? and this is for on road use only. Not interested in sinking my daily driver in mud. haha
Old Apr 25, 2013 | 07:17 PM
Zejokee's Avatar
Whats the purpose of lifting it then?
Old Apr 25, 2013 | 07:26 PM
Stroker815's Avatar
cause it looks a lot better. you got daily drivers and you got toys.. this is my daily driver
Old Apr 25, 2013 | 07:33 PM
Curry's Avatar
Why lift it? Because he can. Doubt spacers will make it ride rougher mainly tires do that. Decent shocks that are valved correctly improves ride. Also having tire pressure correct for the front and rear and balanced correctly.
Old Apr 25, 2013 | 07:38 PM
Stroker815's Avatar
I might give the spacers a try then and then find me a good set of shocks. On a somewhat tight budget but this truck is new to me and is 4 inches shorter than my last one so I feel so low to the ground. haha Thanks for the help yall
Old Apr 25, 2013 | 07:41 PM
Curry's Avatar
Np. Don't go cheap on shocks. Get a decent brand or you will just be replacing quicker than expected.
