Maintenance light on trucked died while driving
Old Apr 24, 2013 | 10:47 PM
ih8yourface2's Avatar
Default Maintenance light on trucked died while driving
So about 5 times now my 05 f350 has had maintenance light come on while driving down the road and my truck just dies when it comes on. when I mean the truck dies it still is running and I can still control the truck but I have no throttle response in the truck. I pull over shut off truck and restart it and it will drive fine. What are the causes of the maintenance light even being on that would have this happen. where should I start. I do have an sct livewire ts tuner with custom tunes but when I go to read codes nothing comes up.
I do have an egr delete in the truck now would it be somehow sensing that delete and going off. but I do have a custom tune that should have go rid of that code permenantly.
Old Apr 25, 2013 | 04:26 AM
97cummins's Avatar
In some ecu's i've seen,there is a setting for the maintnance light so when the ecu thinks the truck needs serviced it will throw a maintnance light.And it sounds like it's putting your truck into a limp mode.
But thats my guess,and thoughts.
Old Apr 25, 2013 | 09:20 AM
MillerBoyzDiesel's Avatar
You may have a apps problem. Most fords with throttle by wire will set a maint. req. light if it has a fault and go into limp mode. Check codes.
Old Apr 25, 2013 | 10:28 PM
no codes are coming up wen light is on or off even ford dealership didn't find a code.
Old Apr 25, 2013 | 10:55 PM
Ah ok. Its not the light for the air filter minder is it? Ive never seen one kick a limp mode for that tho
1ATony
1A Auto Parts
Jul 30, 2015 12:44 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
