93 cummins only clicks
Old Apr 24, 2013 | 08:21 PM
wyowelder's Avatar
Default 93 cummins only clicks
Drove home in a blizzard last week everything was good next morning no start put a charger on still won't start and only clicks like crazy. new starter still no go what the hell is goin on
Old Apr 25, 2013 | 04:37 AM
97cummins's Avatar
possable starter relay going out
Old Apr 25, 2013 | 09:12 AM
wyowelder's Avatar
Put 12 volts thru relay contact grabs and has full continuity on the other posts don't have a clue what's goin on here
Old May 2, 2013 | 03:37 PM
1993firstgennewbie's Avatar
I bet your cables are going bad, or there is a wire junction on the driver fender with 5 wires coming from the cab to a sealed ruber thing with 2 wires going to the battery ive had lots of problems like this with mine and I eventually took a piece of copper drilled 2 holes and attached the wires that way and its been good ever since. it gets coroded inside and causes quite a few different problems. with mine, when I first got it it caused the truck to shut down randomly, then it caused the truck to do what you are decribing and I thought it was the starter, aand then it caused the headlights, radio, and heater not to work. im 90% sure this is your problem
Old May 10, 2013 | 09:04 PM
wyowelder's Avatar
Thanks guys it was a combination of a burned sending wire to the starter and an arc pit on the cable connection
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
JoeyMiR
9
Feb 3, 2018 10:05 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
