Painting Suspension?
Old Apr 23, 2013 | 08:27 PM
Curry's Avatar
Default Painting Suspension?
Well I just got back from working in Alaska and figured it was time to do some upgrades. Have a hydro assist kit, new rear shocks, and fabricating a diff cover mount for the hydro assist. (oh and an on board air system with a Nathan Airchime K5LA horn ) A good majority of the parts for suspension lift the paint or powder coat is cracking/peeling. Is there any at home painting products (spray paint) that will hold up pretty decent? Don't really have or want to drop the $$ to drop on powder coating everything unless I have to. Also what about painting leaf springs?
Old Apr 23, 2013 | 08:32 PM
bobfbigman's Avatar
I used some restore paint?? the stuff that turns rust to a hard coating, then just used a decent spray paint to seal them up good.
Old Apr 23, 2013 | 08:34 PM
CR9712v's Avatar
its all about prep, what do you plan on doing before you start painting everything?...
Old Apr 23, 2013 | 08:37 PM
Curry's Avatar
I plan on stripping all old paint and or rust off. Sanding if needed. Then hitting parts with a degreaser if needed. Pretty much I will start off with the cleanest bare metal I can get to.
Old Apr 23, 2013 | 08:47 PM
CR9712v's Avatar
sounds like a plan . powder coat is more cohesion then adhesion, so its probably not sticking to the metal underneath if it wasn't prepped or baked right. so more then likely your going to need to redo what's ever powder coated. but paint wise what parts are you specifically trying to paint?
and for leaf springs your better off rattle canning it.. they rub a lot and its probably going to be a pain in the *** to keep touching up. and costly.
Old Apr 23, 2013 | 08:49 PM
Curry's Avatar
Everything I can. Drag link + bracket, track bar, front diff cover after i fab it, bump stop brackets, rear diff, drive shaft, maybe my traction bars. Going to clean and recoat frame rails where needed. Thats what im thinking for leaf springs. Anyone have good success with certain kinds of spray paints as to durability for everything else?
Old Apr 23, 2013 | 09:01 PM
CR9712v's Avatar
I don't really know as 2 a can paint, but make sure you mask off the threads, paint can get thick and make putting everything back together a pain.
ohhhhhhhh try engine enamel paint, extra 5 bucks a can but its very very very durable. few coats will make it look right.
Old Apr 23, 2013 | 09:09 PM
Curry's Avatar
I will def be covering anything threaded before painting. Just have to figure out a color to go with the black and chrome look
Old Apr 23, 2013 | 09:15 PM
CR9712v's Avatar
yeah man good luck. hope I helped. its hard to get around here.
boostkid
Jun 3, 2015 11:16 PM
Apr 30, 2015 08:10 AM
6.Revvin
Tire, Wheel & Suspension
Apr 30, 2015 05:09 AM
carid
Diesel Bombers Sponsors
Apr 22, 2015 09:28 AM
Twelve valves
Price Quote - Request A Price
Jan 18, 2015 05:36 AM
