97 powerstroke turbo question
Old Apr 23, 2013 | 08:44 AM
autostroker's Avatar
Default 97 powerstroke turbo question
Can someone tell me what the stock turbo on a 97 powerstroke is?
Sent from my SCH-R760 using Tapatalk 2
Old May 6, 2013 | 08:47 AM
thorraven's Avatar
The stock turbo on the 1997 7.3l was a GTP38R or the GT37 if your truck was built in early 1996 as a 97 model. Below is some info on the 38r.
STOCK GARRETT TP38R
Compressor wheel inducer diameter: 59.87 mm (60 mm)
Compressor wheel exducer diameter: 80 mm
Compressor housing A/R: 1.10
Turbine wheel inducer diameter: 76.2 mm
Turbine wheel exducer diameter: 69.84 mm (70 mm)
Turbine housing A/R: 1.15
Old May 6, 2013 | 09:18 AM
joebob3093's Avatar
Moderator
Way wrong
The stock turbo on a 97 is a TP38
The GTP38 was on the SD and the GTP38R is an aftermarket upgraded turbo for the SD. Pretty sure the GT37 is what came on the 6.0 and is a VGT turbo.
Old May 6, 2013 | 09:47 AM
thorraven's Avatar
sorry i got my years backwards.. yes the tp38 is on the old body style 97's the new body style 97's have theeither the tp38 or the gtp38 (the "R" was a typo, sorry) but yeah ur right the 37 came on the 6.0.
Old May 6, 2013 | 12:28 PM
thanks guys, got the turbo back in, didnt need to do anthing to it, Pedistal ebp actuator was leaking oil, so i gutted it, put a good down pipe in, changed the CCV so it doesnt go into the intake and got rid of the Cat. Broke the darn IPC sensor when i was prying the firewall back though. There was a $100 mistake......
makuloco2000
Dec 20, 2015 11:19 PM
Rclemson
Ford Powerstroke 2011-Up 6.7L
Jul 26, 2015 04:10 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
