Running hot
Old Apr 22, 2013 | 10:52 PM
Coasteraz's Avatar
Default Running hot
Added 90 hp injectors along with throttle plate to my 98 2500 5 SPF. Have plenty of power pulling 10k on gooseneck, but runs hot pulling. 4 core radiator,4:04 rears. What can I do to help cooling ?
Old Apr 22, 2013 | 10:56 PM
RanchhandTCR's Avatar
Either add more air into the cylinders to help pull more cooler air, adjust timing so you are not burning so much diesel unburnt fuel equals more heat. Id you can ad your mods to your signature so we know what ya got.
Old Apr 23, 2013 | 10:42 PM
sweetv8s10's Avatar
Do you have guages?
Old Apr 23, 2013 | 11:15 PM
Coasteraz's Avatar
Default Running hot
Just stock gauges. Was pulling same hills with same load,no problem. Installed 90 hp injectors,now the heating starts. Gauge gets up to 190-200 then in seconds,buzzer sounds,gauge pegs. Drop down to 3rd gear,crawl to the top of grade.
Old Apr 24, 2013 | 07:08 AM
coalroller12valve's Avatar
do you have a temp cycling thermostat if u do it will heat up to almost the red zone and drop back down. try looking into a non temp cycling thermostat
Old Apr 24, 2013 | 07:50 PM
kapnhook's Avatar
u need an egt guage before u melt a piston.
j1004ss
9
Dec 23, 2021 02:59 PM
realtrucksrattle
May 15, 2015 11:20 AM
Max713
Apr 17, 2015 01:18 AM
Dustin M
Mar 17, 2015 08:59 PM
carid
Diesel Bombers Sponsors
Jan 12, 2015 04:32 AM
