Lights on but won't Start???
Old Apr 22, 2013 | 02:28 PM
Ram904's Avatar
Default Lights on but won't Start???
Truck running fine , turned it off for a few minutes turned it back on. lights came on glow plug light went out . turned the key to start and nothing. Tried it three or four more times and nothing. Moved the gear shift to neutral and nothing. checked fuses under hood - looked ok- moved relays around and still no start. Jumped out neutral safety switch and nothing. bought a new start switch and nothing. Removed and tested starter OK- ran wire to solenoid and to a momentary start button and back to battery + / turned on the switch and waited for glow - pushed start button and it started. Strange AC blower not working , Electric windows not working and Air bag light on??????? Am I missing a fuse or relay or link or What????? Where would it be??
Old Apr 23, 2013 | 03:27 AM
97cummins's Avatar
Ho do the fuses and fuseable links look in the fuse box in the engine compartment?
Old Apr 23, 2013 | 08:26 PM
SRTcummins's Avatar
Is this another one of those collision issues? I remember somewhere that somebody couldn't get their truck started because their computer sensed a accident.(it threw a code)
Correct me if I'm wrong anybody.
Old Mar 9, 2014 | 10:23 AM
Mack Diesel's Avatar
Im having same problems but I can hear a clicking sound coming from my fuse box in the cab. All dash lights come on my fass pump runs but when I turn it over my radio goes blank and I hear those clicking noises
Old Mar 9, 2014 | 05:25 PM
lilmike1540's Avatar
How old are the baterys my truck was doing this and the cranking amps just got too low
Old Mar 21, 2014 | 08:38 PM
Greenbeast's Avatar
My guess is low battery voltage to the ECM. Could just be batteries.
Old Mar 21, 2014 | 08:58 PM
I did soke reserch and there is alot!!! Of issues with the same type of problems and ppl are saying bad ecm....for your sake i hopd not
Old Apr 20, 2014 | 08:07 AM
cruzer1971's Avatar
Did you figure out the problem? I am having similar issues and cant figure it out yet. I ended up running wiring into the cab to jump the starter and everything works fine, just cant start it with the key
carid
Diesel Bombers Sponsors
May 7, 2015 06:40 AM
carid
Apr 15, 2015 07:29 AM
ronstop
Feb 26, 2015 09:48 AM
carid
Jan 6, 2015 06:28 AM
bypass-21
Jan 3, 2015 04:47 PM
