A few maintenance questions
i have a 2001 dodge ram. info in signature.
had a few questions about what filters and intervals you guys are doing on them as my 1st oil change since buying it is coming up.
my truck has a BHAF on it, and i do not know what part number or where to get it. what part number/brand are you guys using? how often do you change this?
should i get the airdog brand fuel filter and water separator? how often are you changing both of these?
should i run a fleetguard oil filter?
thanks in advance, just making sure i've got all the right things
I run a part syn. oil for my motor, at an interval of 7500 miles.
I had a stage 2 afe air filter, which i clean once a year.
I just use the stock fuel/water seperator filter
And i usually run a dodge oil filter
i run rotella T and this oil change will be 7500 miles. going to change everything because i dont know how long the previous owner had everything on there.
oil and oil filter = 7500 miles
fuel filter = 15000 miles
BHAF = 50000 miles
water separator = 50000 miles
the part numbers i have found by searching are:
Fleetguard oil filter - LF3894
Fleetguard fuel filter - FF5613
Airdog water separator - WS100
Fleetguard BHAF - AH19037
is that a pretty good setup?
BHAF = 50000 miles
Jesse92cummins
Jun 10, 2015 04:48 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
