Hpop
Old Apr 20, 2013 | 01:21 AM
BROWNBROS-BEN's Avatar
Default Hpop
Just looking for info,
My truck runs fine,just wondering about things
Update on truck info
06 f250 ,motor mods are , blue spring , afe incooler tubes and intake elbo,
New turbo , egr "bullet proof" cooler, newer injectors, new oil cooler, cold air intake
4" turbo back exhaust, tank sump kit with lift pump to stock pump.
I run innovative custom tunes on it , put ex street on it like two years ago
(with stock head bolts) 100000 km later no problem...
Here s my plans coming up , I putting in arp studs , ford gaskets, maybe egr delete, hpop update fitting
I have 4 gauge pillar volt, boost, pyro, fuel press, and then edge cts insight - with
Ect,eot, trans temp , gear and turq convert, injector pulse, icp, ficm
I was just wondering what most guys icp pressures are
As I don't think I have ever seen mine go over 1700 psi
Usually idle like 500-600 , going down rd 900-1500,
Wot 1400-1700. I thought ideas suppose to go as high as
4000psi?
The truck hasn't lost any power and always runs , starts fine ( except for alittle cold injector sticking on cold mornings till oil is 150*)
Any thoughts ?
O ya one more thing , latey I noticed the egt will get pretty hot if I keep on the pedal!
Like I can bury the needle to and prob passed the 1600* , I noticed it will get hotter faster
Since my little lift pump died and only running stock one . But figure that shouldn't have anything to do with it.
Anybody know how much cooler it would run with egr delete ? Oppose to keeping it ?
Last edited by BROWNBROS-BEN; Apr 20, 2013 at 01:21 AM. Reason: Automerged Doublepost
Old Apr 20, 2013 | 12:42 PM
bobfbigman's Avatar
High EGTs meens you are not getting enough air or too much fuel, I have never seen 1500 on my guage even while towing heavy loads. check the air filter to make sure it is clean and a EGR delete will probably bring you down 100-200 degrees. I would highly recommend that you get a coolant filter on that thing as soon as possible so your new oil cooler doesn't get clogged again, coolant filter is the most important things to add on these trucks.
chen
Jul 24, 2015 02:50 PM
Powerstrokin7.3
Jun 13, 2015 08:47 PM
bajahigh
Mar 24, 2015 10:12 PM
BlackOut96
94-98 7.3L Performance
Dec 11, 2014 07:24 PM
blakec
Nov 29, 2014 10:48 PM
