What triggers active Regen in the dpf
Old Apr 18, 2013 | 08:57 PM
jepledger's Avatar
Default What triggers active Regen in the dpf
Just trying to wrap my head around this DPF thing. What is the sensor input and initiation process for the truck to start the active DPF regeneration process up to the computer adding too much fuel?
Old Apr 20, 2013 | 04:16 AM
97cummins's Avatar
Basicly the sensors in the dpf measure the soot load pressures and the ecu starts a regen process where fuel is sprayed into the exhaust before the dpf.And that increases the temps so the catalyst burns off the excess soot.
Hope this helps.
I'll see if i can find some better info on this.
Old Apr 20, 2013 | 04:34 AM
97cummins's Avatar
Here you go
I got this from wikipedia
Regeneration
Diagram of the regeneration
Regeneration is the process of removing the accumulated soot from the filter. This is done either passively (from the engine's exhaust heat in normal operation or by adding a catalyst to the filter) or actively introducing very high heat into the exhaust system. On-board active filter management can use a variety of strategies:
1.Engine management to increase exhaust temperature through late fuel injection or injection during the exhaust stroke
2.Use of a fuel borne catalyst to reduce soot burn-out temperature
3.A fuel burner after the turbo to increase the exhaust temperature
4.A catalytic oxidizer to increase the exhaust temperature, with after injection (HC-Doser)
5.Resistive heating coils to increase the exhaust temperature
6.Microwave energy to increase the particulate temperature
All on-board active systems use extra fuel, whether through burning to heat the DPF, or providing extra power to the DPF's electrical system, although the use of a fuel borne catalyst reduces the energy required very significantly. Typically a computer monitors one or more sensors that measure back pressure and/or temperature, and based on pre-programmed set points the computer makes decisions on when to activate the regeneration cycle. The additional fuel can be supplied by a metering pump. Running the cycle too often while keeping the back pressure in the exhaust system low will result in high fuel consumption. Not running the regeneration cycle soon enough increases the risk of engine damage and/or uncontrolled regeneration (thermal runaway) and possible DPF failure.
Diesel particulate matter burns when temperatures above 600 degrees Celsius are attained. This temperature can be reduced to somewhere in the range of 350 to 450 degrees Celsius by use of a fuel borne catalyst. The actual temperature of soot burn-out will depend on the chemistry employed. The start of combustion causes a further increase in temperature. In some cases, in the absence of a fuel borne catalyst, the combustion of the particulate matter can raise temperatures above the structural integrity threshold of the filter material, which can cause catastrophic failure of the substrate. Various strategies have been developed to limit this possibility. Note that unlike a spark-ignited engine, which typically has less than 0.5% oxygen in the exhaust gas stream before the emission control device(s), diesel engines have a very high ratio of oxygen available. While the amount of available oxygen makes fast regeneration of a filter possible, it also contributes to runaway regeneration problems.
Some applications use off-board regeneration. Off-board regeneration requires operator intervention (i.e. the machine is either plugged into a wall/floor mounted regeneration station, or the filter is removed from the machine and placed in the regeneration station). Off-board regeneration is not suitable for on-road vehicles, except in situations where the vehicles are parked in a central depot when not in use. Off-board regeneration is mainly used in industrial and mining applications. Coal mines (with the attendant explosion risk from coal damp) use off-board regeneration if non-disposable filters are installed, with the regeneration stations sited in an area where non-permissible machinery is allowed.
Many forklifts may also use off-board regeneration - typically mining machinery and other machinery that spend their operational lives in one location, which makes having a stationary regeneration station practical. In situations where the filter is physically removed from the machine for regeneration there is also the advantage of being able to inspect the filter core on a daily basis (DPF cores for non-road applications are typically sized to be usable for one shift - so regeneration is a daily occurrence).
Old Apr 20, 2013 | 09:05 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
the pressure switch that measures pressure on each side of the dpf starts the ball rolling on the regen process.
Old Apr 20, 2013 | 09:35 AM
cummins05's Avatar
It all means bad fuel economy! which is why i think def is not a bad idea in the new ones.
Old Apr 20, 2013 | 10:25 AM
jepledger's Avatar
Thanks for wikiepia. I am curious what role the egress plays in the regeneration process. From my reading it it seems for prevent regen if its not working?
Old May 20, 2013 | 11:13 PM
Newt's Avatar
The regeneration process is started by either pressure differential from soot buildup or time. It will regenerate from time even if there is not enough soot to trigger it.
Sag2 posted a very detailed explanation of the regeneration process quite a while back on the TDR forum. You might find it if you dig hard enough.
It's like the oil change info, when the EVIC signals , but, not to exceed 7500 miles or 6 months, whichever comes first.
Newt
Old May 24, 2013 | 05:19 PM
hotsparky's Avatar
Up 2008 6.7
new stacks dichted the edege new mini maxx very happy thanks
stillcummin
Feb 18, 2016 08:13 PM
sleepysubie
12
Jun 23, 2015 02:21 PM
Dr.G
Ford Powerstroke 08-10 6.4L
Jan 26, 2015 12:15 AM
mrweasel
Oct 25, 2014 05:47 AM
jmed795
Oct 7, 2014 03:51 AM
