Need a answer to p1689 code please
Old Apr 18, 2013 | 07:03 PM
iceman1404's Avatar
Default Need a answer to p1689 code please
If my truck threw a p1689 and I cleared it should it come back again as I try to start the truck? if it does not come back does that mean ecm and vp are ok?
Old Apr 21, 2013 | 01:00 AM
blacksally's Avatar
i have that code all the time it comes with my programmer
Old Apr 28, 2013 | 06:55 PM
Verk86z's Avatar
Could be a bad connection too. Worthwhile to check your grounds for looseness, corrosion, etc...
Old Apr 29, 2013 | 10:29 AM
jkidd's Avatar
Check the fuel system relay. swap it with another in the fuse box.
Old Apr 29, 2013 | 11:40 AM
Ltk's Avatar
Ltk
i also have that code at all times ever since i bought and installed my smarty programmer on my 2001
P1689 - No communication between ECM & Injection Pump Module
Old Apr 30, 2013 | 10:10 AM
01CumminsPower's Avatar
could it mean the vp44 is going out? because mine thru that code and my truck died on the road. i have lost all power and fuel milage even tho the code went away. ive checked all wires and there fine.
Old Apr 30, 2013 | 12:40 PM
Ltk's Avatar
Ltk
Do you have a fuel pressure gauge? If so did your pressure drop rapidly or was it running lower than normal?
Old May 1, 2013 | 08:55 PM
Cumminnotstroking's Avatar
Check out bluechipdiesel.com... It will tell you everything you need to know about your fuel system.
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
rowekmr
May 31, 2015 09:03 PM
robbyS
Apr 16, 2015 02:22 PM
UC Kid
Nov 7, 2014 10:56 PM
