Bigger injectors
Old Apr 18, 2013 | 10:50 AM
CoalRoller92's Avatar
Default Bigger injectors
Ok guys I'm thinking about putting bigger injectors in my truck and a air dog truck is pretty much stock except edge JWA cai and exhaust would 150 sticks with a 95 gh air dog be good?? Thanks
Old Apr 21, 2013 | 01:06 PM
shellinger's Avatar
should be ok. just be careful if you tow a lot you are going to need to upgrade your turbo. your egts will be much higher with a stock turbo and 150 hp injectors. i have a fass 150 and the lowest fuel pressure i have ever seen was 9 with both smarty and adrenaline turned almost all the way up. if you are going to do injectors make sure you get an egt gauge and fuel pressure gauge first so you can keep your truck running .
Old Apr 21, 2013 | 03:17 PM
My edge has has both egt and fuel pressure is there anything else I need besides a fass or airdog to run 150 sticks? Thanks
Old Apr 21, 2013 | 05:17 PM
You will need to upgrade to a larger turbo
Luke
Old Apr 21, 2013 | 06:56 PM
What about the vp
Would it be better to run 125 sticks because this my DD will my mileage drop any?
Last edited by CoalRoller92; Apr 21, 2013 at 06:56 PM. Reason: Automerged Doublepost
Old Apr 23, 2013 | 05:23 PM
jkidd's Avatar
Above 100HP you may see a slight drop, but it will be minimal if any at 125HP.
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
strokin97
Sep 30, 2014 11:59 PM
