Egr block off plate
Old Apr 17, 2013 | 07:19 AM
bigred91's Avatar
Default Egr block off plate
I was going down the road yesterday and apparently the bolts holding down the block off plate for the egr valve stripped the threads out of the intake manifold and the plate blew off so my turbo stopped spooling and it was just pouring black smoke out. Can I just tap and die the holes and drill out the plate for bigger bolts or am I gonna have to replace my manifold?
Old Apr 17, 2013 | 07:51 AM
MillerBoyzDiesel's Avatar
drill and tap would save you a lot of time and money
Old Apr 17, 2013 | 07:58 AM
bigred91's Avatar
Alright thanks. I was just making sure it would be okay to do that. Cause I can't afford to replace the manifold
Old Apr 17, 2013 | 08:38 AM
use some grease on your bit and tap to control shavings flying everywhere.
Old Apr 17, 2013 | 08:43 AM
avolnek's Avatar
grease and shop vac while drilling would be highly suggested here!
Old Apr 17, 2013 | 10:27 AM
bigred91's Avatar
Alright thank you everyone!
Old Apr 18, 2013 | 01:25 PM
bigred91's Avatar
Fixed it last night with a heli coil because the parts store didn't have the right size tap. But the heli coil is doing just fine. Thanks for the help guys!
Old Apr 18, 2013 | 01:36 PM
Old May 20, 2013 | 05:31 PM
STLPerformance's Avatar
what i did was keep the egr cooler and everything in tact and used my sct to turn off the functionality of the egr. Good to do?
Old May 21, 2013 | 07:49 AM
You really don't want to keep the cooler. The cooler can still give problems. You could run it the way you have until the cooler lets go and then do your delete and oil cooler kit.
