maintdan
Old Apr 16, 2013 | 03:32 PM
maintdan's Avatar
Default maintdan
I have a 2001 5.9 24valve that smokes diesel smell at idle when it is warm it runs great any ideas would be great replaced injectors Thanks
Old Apr 16, 2013 | 07:15 PM
H.R.D's Avatar
Does it do this only when it's cold outside or all the time? Did you replace with stock injectors or aftermarket ones?
Old Apr 17, 2013 | 08:13 AM
maintdan's Avatar
Does this all the time you start it did not change cross over tubes.put Bosh injectors in runs the same before I changed them the lift pump was changed a year ago. after it runs for 10 minutes or so clears out and runs great no smell or smoke Thanks
