Erratic idle after warm-up
Old Apr 16, 2013 | 09:28 AM
nappy1995's Avatar
Default Erratic idle after warm-up
Hey guys,
Been noticing a little bounce in the idle after I let the truck warm up. It's barely noticeable but it's been irritating me. After I drive it and come to a stop it's a little worse. It feels and sounds like a miss or something.
Y'all can see what I've done to the truck from the sig. I called Thoroughbred Diesel and was told it's probably a leaking feed tube.
Any thoughts?
Old Apr 16, 2013 | 12:13 PM
Dock's Avatar
It could be as i had a similar issue and resolved it with a draw straw 5. Do the air in in the fuel test with clear hose under load before dropping the tank. Could be a number of things so start test, not replacing.
Old Apr 16, 2013 | 01:10 PM
nappy1995's Avatar
I'll do the air in fuel test on my next day off, it's not my daily driver. I was extremely methodical when I installed the injectors, not torquing until positioned with feed tubes correctly etc. I did not replace feed tube o-rings but I inspected all tubes thoroughly inside and out and found no scarring or pitting or anything out of the ordinary. I really don't think it's the feed tubes as I can't detect any fuel in the engine oil.
Any way, I appreciate the help.
Old Apr 16, 2013 | 01:48 PM
MillerBoyzDiesel's Avatar
fuel tubes wouldn't cause fuel in oil.As far as Fuel tube orings they could cause a hard start after sitting for a while. Could be a prob with injectors or pump.
Old Apr 16, 2013 | 01:59 PM
nappy1995's Avatar
The truck starts right up and runs great. No leaks anywhere and I have no other problems other than the idle. I've got 17 rock solid psi at idle and great throttle response, mileage etc.
Old Apr 17, 2013 | 08:51 AM
when did the problem start?
Old Apr 17, 2013 | 02:07 PM
nappy1995's Avatar
The problem started after the VP, injectors and AirDog were installed.
Old Apr 17, 2013 | 09:21 PM
Hot rod vps can have a funny idle at times but i ddnt see that you have a hotrod. What brand injectors? What year truck? Did you do nozzles or full injectors?
Old Apr 17, 2013 | 09:33 PM
dieseldude848's Avatar
Sounds like its an injector miss fire/ pop pressure not correct
Old Apr 18, 2013 | 07:09 AM
nappy1995's Avatar
It's a S.O. VP and the injectors are from Industrial Injection. The truck only has 89 K miles.
