How do I know if my trucks a ho
Old Apr 15, 2013 | 11:46 PM
CoalRoller92's Avatar
Default How do I know if my trucks a ho
On my build sheet is says cummins "600" does this means mines the HO or no and if not what is the difference??
Old Apr 16, 2013 | 12:45 AM
H.R.D's Avatar
Are you talking about your 2001? If so, if its a 6 speed its an HO, with 245hp.
Old Apr 16, 2013 | 07:22 AM
Yes I am ok so it's just the 235 then can I make it a HO?
Old Apr 16, 2013 | 07:43 AM
stodg73's Avatar
Look at the VIN, in the 8th position there should be a 6 or 7, if 6 then it is a S.O, if 7 then it is a H.O. This is true unless the VP has been replaced then it could be any combination.
Old Apr 16, 2013 | 08:37 AM
It has a 6 I know I have the updated lift pump on it idk bout the vp44
Thanks guys
Last edited by CoalRoller92; Apr 16, 2013 at 08:37 AM. Reason: Automerged Doublepost
Old Apr 16, 2013 | 08:50 AM
stodg73's Avatar
You can also look at the information on the VP to see which one that you have. It will either state 235 hp or 245 hp on the label.
Old Apr 20, 2013 | 01:11 PM
01quadcab's Avatar
your better off with a so pump just add a set of rv 275 injectors and you will love it. what upgraded lift pump? if it's the in tank one better get that taken out and put on a real pump or your going to be buying a new injection pump
Old Apr 20, 2013 | 06:09 PM
It has the mopar one
Old Apr 21, 2013 | 02:12 AM
01quadcab's Avatar
thats not a good thing they don't live very long keep the fuel pressure above 7psi
Old Apr 21, 2013 | 07:56 PM
Elimin8r's Avatar
My build sheet says "5.9L TD HO Eng(ETH)/6Spd M/T NV5600"
Jan 22, 2015 11:40 AM
Jan 6, 2015 12:10 PM
Nov 5, 2014 07:00 PM
Nov 1, 2014 08:20 AM
Oct 20, 2014 08:10 AM
