removed trans now Won't start
Old Apr 15, 2013 | 04:52 PM
stock_12V's Avatar
Default removed trans now Won't start
pulled the auto trans from my 97 ram 3500 parts truck today and now the engine wont turn over
anyone know how to bypass the neutral safety switch?
Old Apr 16, 2013 | 03:30 AM
97cummins's Avatar
It's possable you can just use a paperclip put in the plug.
and check to see if your fuel shutoff solinoid is up.
Old Apr 16, 2013 | 11:52 AM
stock_12V's Avatar
no to familar with the fuel solenoid where is it and what do i need to look for to see if its up
Old Apr 16, 2013 | 04:43 PM
93_Fummins's Avatar
This...(looking on the driver side, between the intake horn and brake reservoir)
It's on the driver side of the injection pump, toward the rear. A cylinder looking thing-a-ma-bob with a 3-wire pigtail coming out of the top. It's an electronic solenoid that has a "pull" and "hold" function for the fuel shutoff lever on the side of the pump. When you turn the ignition on, the lower amp "hold" function activates, but cannot physically pull the lever on the pump up. When you crank the starter, the higher amp "pull" function activates pulling the lever up, then letting the "hold" function do it's job once done cranking.
You can turn the ignition on and manually pull the lever up to activate the fuel supply in the pump, iirc. However, if you override the neutral safety switch then just have someone watch to make sure the solenoid pulls the lever up when cranking. As to overriding the switch, you'll have to isolate it on the transmission pigtail and make a jumper to ground it out, I believe....but I'm not familiar what wires it would be.
Old Apr 16, 2013 | 07:32 PM
stock_12V's Avatar
hanks guys sounds easy enough,ill be selling this motor so ill be glad to know i can start it again
Old Apr 16, 2013 | 09:56 PM
sweetv8s10's Avatar
Are you saying it won't do anything when you turn the key? If so then I would say it's the neutral safety switch especially since you took the tranny out. Because that means it's not plugged in to the transmission to tell the switch it's in park.
Old Apr 17, 2013 | 10:10 PM
stock_12V's Avatar
yes sweet v8 it will not do a thing when yopu turn the key im going to try to paper clip metho
d today
Update for anyone who runs into this problem all I Did was cut the plug off and twist the wires together and it fired right up..of course this is a truck I'm parting out so the plug didn't matter
Jake9473
Jul 22, 2018 08:19 AM
cjgregory
Mar 31, 2015 01:45 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
Ibanimal
Oct 31, 2014 09:07 AM
