6.0L surges at idle
Old Apr 14, 2013 | 06:45 PM
rowekmr's Avatar
Default 6.0L surges at idle
I noticed that my recently bought 03 Excursion 6.0L sometimes surges at idle. I notice when at stop lights with the truck in D that I can hear the rpms go up a little then back down. If I am lightly holding the brakes the truck will move a little each time. It has fresh 10W-30 syn oil, new EGR and new filters (all factory). What can be some causes of this?
Old Apr 14, 2013 | 06:53 PM
bobfbigman's Avatar
A bad icp sensor is known to make the motor surge, there was also a reprogram that was done to get rid of a idle surge, if it is the reprogram problem leave it alone, the reprogram they do alos kills the mileage.
Old Apr 14, 2013 | 08:28 PM
rowekmr's Avatar
Ok Ill check into that. Reading your sig are you still on the factory bolts or studs? How do you like the Banks IC?
Old Apr 14, 2013 | 09:26 PM
bobfbigman's Avatar
Just put studs on 2 weeks ago, the stock bolts hadn't let go yet but I was pulling motor anyway to upgrade my high pressure oil system to the 05 and later system which also involved changing rocker boxes so the head bolts had to come out. 268k isn't bad for factory bolts but I was always carefull when towing.
The Banks intercooler is nice but I don't like there intake elbo so when I orderd the setup I also ordered a CFM largemouth kit and gave the banks elbo and the cfm cooler pipe/goes from 2 1/2 to 3" for the largemouth/ to my sister for her truck..
Also after the replacement of head gaskets and adding studs it did seem as I had more power so it might have been the newer HPOP or might have had a gasket leak between cylinders.
Last edited by bobfbigman; Apr 14, 2013 at 09:26 PM. Reason: Automerged Doublepost
Old Apr 14, 2013 | 10:03 PM
ih8yourface2's Avatar
either bad sensors on the truck or what happened when i use to own an jeep 2011 diesel and that happened was one of my injectors was literally all messed up and it was frayed to the point if it got hot or wet or anything it would spark and too much electricity was getting in there and messing with the computer but that was rare i was told. so go with first option lll!!!!
Mc Merc
Dec 17, 2014 02:24 PM
Mc Merc
Dec 16, 2014 06:59 AM
Dec 10, 2014 08:10 AM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
