48re tranny please help
Old Apr 11, 2013 | 06:54 PM
killinskeeters's Avatar
Default 48re tranny please help
new to this site as a member but I scour this site all the time for info. I need help with my 07 dodge with 5.9. viewed dozens of threads on tranny upgrades here and pulled the trigger on buying parts. bought all my parts from patc and took my truck and parts to my tranny guy. 1000 dollars later for parts and labor and 1-2 is great, 2-3 shift brings you out of your seat and sluggishly goes into gear. 3-4 shift is firm like 1-2. I ordered a transgo kit, sonnex intermediate servo, sonnex accumulator, billet band strut and anchor and the billet gm pressure regulator conversion. my tranny guy called transgo they told him their shift kit isn't designed to work with the servo and accumulator. I called patc and Nathan in the tech dept tells me that I need to drill a couple holes in the separator plate bigger to solve the problem of fluid flow. I had my tranny guy call patc to confirm and another guy in their tech dept tells him they don't do that anymore all they do is change out the apply lever to a 4.4 I think he said. please somebody help. I have read so many threads that so many people have installed the same parts and have had great success???????
Old Apr 12, 2013 | 08:02 AM
dangerous1965's Avatar
Could it be something simple like a band adjust? Have your tranny guy back it off or you can one full turn and then try it! "Front Band" Buy a valve body from Goerend! Their constant pressure unit is awesome!
Old Apr 12, 2013 | 08:41 AM
MillerBoyzDiesel's Avatar
If you ordered the transgo diesel vb reprogramming kit, it is very in depth and allows for various options and is for use in 47 and 48s. You have to pay close attention to what you have in front of you and what you are trying to accomplish with the trans. Your tranny guy may have skipped a step or misread something. I have never had any problems with gm gov. press. solenoid or sonnex pieces. Its always worked great.
Old May 21, 2013 | 07:49 AM
crazyrocks's Avatar
1)what band lever did they send you? should be stamped on it a (4.8 should be fine)
2)recheck your band adjustment, i don't have it in front of me but I believe it is 73in/lbs then back 1 and 1/4 for the 48re.
3)call Goerend they work magic...
I've never seen that much trouble from transgo or sonnax it sounds like you may want to try another transmission shop...?
and please update I'm curious what the issue turns out to be.
back it off ***1 and 3/4***
Last edited by crazyrocks; May 21, 2013 at 07:49 AM. Reason: Automerged Doublepost
Kfohne21
10
May 12, 2022 10:13 AM
InheritedDiesel
Jun 3, 2015 09:39 PM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Trevlar11
Nov 16, 2014 01:59 PM
