Check Engine Light again
Old Apr 11, 2013 | 11:25 AM
BDbomber's Avatar
Default Check Engine Light again
So I have posted this issue before, however, the last time my engine light came on I just needed to clean my MAP and IAT sensor. Problem was solved.
Starting a couple days ago, my engine light came back on, but this time I threw:
P1693:Fault in Companion Module
P0236:Map too high
P0234:Turbo Boost limit exceeded
P0237:Map too low
I am not as concerned about the MAP sensor, since i do have an exhaust break and that tends to get dirty.
The Turbo and fault in companion module are scaring me!
I am considering taking off my Edge tuner and my exhaust break and hope that there is a fault in one of those, which is sending too much exhaust into my turbo.
The Edge has two spliced wires, 1 is plugged into another sensor and the other is plugged into my BD lift pump.
Silly question: After taking off the tuner, where do those plugs go?
If this doesn't work, what are the chances I need a new computer?
Thank You!
burndiesel
10
Feb 7, 2023 01:15 AM
Higgy
Jun 5, 2015 09:16 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
Rebel_redneck
Sep 29, 2014 11:05 AM
