abs and brake light on
Old Apr 10, 2013 | 06:59 PM
04cummns's Avatar
Default abs and brake light on
hi my abs and brake light are both on and came on at the same time. after doing some research i found that it could be a fuse so i checked and none were burnt out. brought it to a shop and they gave me abs codes 37,36,26,and 35 if anyone could help that would be great
Old Apr 11, 2013 | 05:34 AM
minncountryboy's Avatar
Does your speedometer seem like it is slow to pick up? Or delayed? Like stay at 0 and then just shoot up to speed?
Old Apr 11, 2013 | 05:58 AM
04cummns's Avatar
Speedometer works fine. I was told that you can use a voltmeter to check the sensors. Does anyone know how many these trucks have
Old Apr 11, 2013 | 11:42 PM
ridgeram's Avatar
had the same sort of issue with my clockspring behind the steering wheel only difference was my air bag light was also on and still is
Old Apr 12, 2013 | 09:59 PM
CHEMMINS's Avatar
Rear diff sensor. Either the sensor or the small wiring harness that goes to it.
Hawkeye O'nelove
Sep 26, 2015 05:42 PM
asajay
10
Sep 8, 2015 10:40 PM
wolf1365
Jul 31, 2015 03:43 PM
Gitana
Nov 25, 2014 06:25 PM
