1993 6.5 into 1995 6.5
Old Apr 9, 2013 | 09:00 PM
Levis95's Avatar
Default 1993 6.5 into 1995 6.5
Swapping a 1993 6.5 with lower kms into my 95 as my motor is experiencing a lot of blow by. My harmonic balancer broke on the drive home (2.5 hour drive) and I didn't even hear it and that screwed my old motor up now im swapping in this 93 6.5. I am changing the injector pump over and a couple other things. Can I use the 93 wiring harness in the 95? I don't think I can but my harness is all screwed up so I thought id ask. also any tips or suggestions would be awesome. I will take pictures of progress then post! Also will be parting out the 93.
Old Apr 10, 2013 | 11:45 AM
racer55's Avatar
You will need to stick with the 95 harness so it can connect with the IP.
The IP requires electronic timing and only a tech 1,tech 2 with OBD 1 expansion pack or GMTD ScanTech can accomplish this.
You will also need to install a 94+ timing chain set and balancer on the 93 shortblock along with the 95 timing cover with CPS.
6.5jones
6.2L & 6.5L Performance
11
Apr 3, 2017 01:38 PM
old chevy
Sep 2, 2015 08:42 AM
glasspack
Jul 29, 2015 11:04 AM
airspeed181
Jan 19, 2015 09:00 PM
gremlin75
Oct 6, 2014 06:10 AM
