07 550 turbo problems
Old Apr 8, 2013 | 09:47 PM
bulldog77's Avatar
Default 07 550 turbo problems
http://i804.photobucket.com/albums/yy325/bulldog77/2013-03-06_08-05-09_126_zpse0a3b842.mp4
This started happening a day after the company bought the truck. I replaced with another used turbo and it still does it but not as often. No boost leaks anywhere and isnt lacking on power. Plus the other 07 550 we have sounds like it has a massive boost leak sometimes at idle but not all the time, again, cant find any leaks and is not lacking on power. The one in the video has been deleted and the other has the sinister egr kit on it. Any suggestions?
Old Apr 9, 2013 | 07:58 AM
MillerBoyzDiesel's Avatar
video don't work
Old Apr 9, 2013 | 07:03 PM
bulldog77's Avatar
I'll try something different, worked on phone and computer.
Sent from the recliner butt naked
Old Apr 9, 2013 | 09:21 PM
bobfbigman's Avatar
kinda looks like it is sticky veins in the turbo, you can pull the turbo and clean it up, I believe th is a How To on this at the top of the 6.0 section, also should be able to find a video on youtube. This happens with trucks that sit alot or idle alot, running them hard every now and then will help keep them clean but once they are gummed up it has to be taken apart and cleaned, its realy not too hard.
Old Apr 9, 2013 | 09:59 PM
bulldog77's Avatar
When I replaced the turbo on the deleted 07 I cleaned the turbo. And this all started after I was pulling a load with a pretty strong head wind and did all it could to keep it at 60 mph. Up to the point before pulling the load it was running great with no problems.
Old Apr 9, 2013 | 10:05 PM
bobfbigman's Avatar
have you checked all the boots to make sure none are torn , also the plastic CAC tube is known to crack and it will release pressure when building boost, if it is the plastic tube replace it with the mtal one like the 03 and early 04 trucks had.
Old Apr 9, 2013 | 10:29 PM
bulldog77's Avatar
All new boots and no cracks in the plastic pipe.
Old Apr 9, 2013 | 10:45 PM
bulldog77's Avatar
This what i was pulling when it started.
Try this video
<iframe src="https://www.facebook.com/video/embed?video_id=10151298052555800" width="1280" height="720" frameborder="0"></iframe>
https://www.facebook.com/photo.php?v...2570981&type=3
avatardvr
18
Aug 8, 2019 12:38 AM
huntman7
Sep 17, 2015 10:03 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
